A-Pillar Guage Pod Install in the Lincoln LS |
By LVC Member Quik LS |
I finally installed my A-Pillar and gauges last weekend. I installed AutoMete r C2 Fuel Pressure and Air/Ratio gauges - can't have my NOS Pressure gauge or I do not pass tech inspection for my ESP class. Here's some pics:
I tapped the fuel line between the valve and the fuel rail - nothing special. I tapped the heated O2 sensor signal off pin28 of the middle PCM connector - pic below: I then ran the wires from the pressure sensor and PCM tap through the PCM rubber seal in the firewall and the behind the dash (through a conduit) to the a-pillar. I tapped the ground and dash lights off my white gauge face leads, tapped a 12v switched source from a lead in the steering column. It was difficult getting the
PCM out - pull the glove box out to get the rear bracing off - pull of
the AC filter and ducting to get at the PCM connector.
This area is intended for Tech Tips submitted by members of LincolnvsCadillac.com. The opinions expressed here are the opinions of the individual author and do not necessarily represent the views of LincolnvsCadillac.com. Undertake these procedures at your own risk. If you have any comments or questions please contact the individual authors. Reader assumes all the risk associated with the installation of aftermarket products. LincolnvsCadillac.com and its owners are not responsible for any direct or indirect damage to the vehicle, person or persons and the resulting costs incurred from the installation or use of these products. LincolnvsCadillac.com recognizes that "Cadillac" and "Chevrolet" and their respective logos, model names and numbers are registered trademarks of the General Motors Corporation. These and other terms used on this website are used for identification purposes only. Lincolnvscadillac.com is not affiliated in any way with the General Motors Corporation, Cadillac, Chevrolet, Mobil or any other website or company listed herein. |
