REMOVAL
1. Disconnect the battery
ground cable.
2. Remove the air cleaner
outlet tube.
3. CAUTION: The coolant drain procedure must be followed exactly or
damage to the engine may occur.
Drain the engine cooling
system.
4. Remove the cowl vent screen.
5. Remove the engine compartment
brace.
6. Disconnect the accelerator
and speed control cables.
7. Disconnect the vacuum
hoses.
8. Disconnect the vacuum
line.
9. Disconnect the EGR valve
to exhaust manifold tube
10. Remove the EGR valve.
- A. Remove the two bolts.
- B. Remove the valve and
discard the gasket.
11. Disconnect the camshaft
position (CMP) sensor electrical connector and separate the connector
from the fuel injection supply manifold.
12. CAUTION: To remove normal fittings, squeeze the tabs and pull straight
out or damage to the fitting may occur.
Disconnect the evaporative
emission canister purge valve line.
13. Disconnect the fuel pressure sensor electrical connector.
14. Disconnect the vacuum
connector from the fuel pressure sensor.
15. Disconnect the fuel line.
16. Remove the electrical
connectors from the bracket.
- 1. LH knock sensor (KS).
- 2. Cylinder head temperature
(CHT) sensor.
17. Remove the nut and the
bracket.
18. Remove the bracket.
- 1. Remove the hose.
- 2. Remove the nuts and
the bracket.
19. Raise the engine wiring harness and disconnect the LH fuel injector
connectors.
20. Disconnect the electrical
connectors.
- · Idle air control
(IAC) valve.
- · Throttle position
(TP) sensor.
21. Disconnect the crankcase ventilation tube from the RH valve cover.
22. Disconnect the hoses (1) from the throttle body and the retaining
clips (2).
23. Raise the engine wiring
harness and disconnect the RH fuel injectors.
24. Remove the Delta PFE sensor.
- 1. Disconnect the electrical
connector.
- 2. Disconnect the hoses.
- 3. Remove the bolts and
the sensor.
25. NOTE: The throttle body
and adapter are shown removed for clarity. It is not necessary to remove
the throttle body and adapter to remove the intake manifold. Remove
the bolts and the stud (2) in the sequence shown.
26. NOTE: The throttle body, adapter and EGR valve are shown removed
for clarity. NOTE: Position the throttle body heater return hose out
of the way before removing the throttle body.
Remove the intake manifold.
27. CAUTION: Do not use metal scrapers, wire brushes, power abrasive
discs or other abrasive means to clean the sealing surfaces. These tools
cause scratches and gouges, which make leak paths. Use a plastic scraping
tool to clean the surfaces.
Clean the sealing surfaces.
- · Inspect the gaskets
and install new gaskets if necessary.
Installation
1. If removed, install the
gaskets.
2. NOTE: Make sure that the throttle body heater return hose is positioned
between the heat shield and the intake manifold.
Install the intake manifold
and tighten the bolts in the sequence shown.
3. Install the Delta PFE
sensor.
- 1. Install the sensor
and the bolts.
- 2. Connect the electrical
connector.
- 3. Connect the hoses.
4. Connect the RH fuel injectors
and position the engine wiring harness.
5. Connect the hoses (1)
and install the hose in the clip (2).
6. Connect the crankcase
ventilation tube.
7. Connect the IAC valve and TPS electrical connectors.
8. Connect the LH fuel injector connectors and position the engine wiring
harness.
9. Install the bracket.
- 1. Install the bracket
and nuts.
- 2. Install the hose.
10. Install the bracket and the nut.
11. Install the electrical connectors on the bracket.
- 1. Install the LH KS connector.
- 2. Install the CHT sensor
connector.
12. Connect the fuel line.
13. Connect the vacuum connector
to the fuel pressure sensor.
14. Connect the fuel pressure sensor electrical connector.
15. Connect the evaporative emission canister purge valve line.
16. Connect the CMP sensor
electrical connector and position the connector on the fuel injection
supply manifold.
17. Connect the EGR valve to exhaust manifold tube.
18. NOTE: EGR valve to exhaust manifold tube is removed for clarity.
- Install the EGR valve.
- 1. Install a new gasket
and the valve.
- 2. Install the two bolts.
19. Tighten the tube.
20. Connect the vacuum line.
21. Connect the vacuum hoses.
22. Connect the accelerator
23. Install the engine compartment brace.
24. Install the cowl vent screen.
25. Install the air cleaner
outlet tube. .
26. Connect the battery ground
cable.
27. CAUTION: The cooling system filling and bleeding procedure must
be followed exactly or damage to the engine may occur.
Fill and bleed the engine
cooling system.
