Installing Brake Rotor Vents on the Lincoln LS |
By: QuickLS I added some brake ducts to my LS - intakes from the lower front grill - through tubing - into the wheel spindles. This should help cool your brake rotors for better braking performance.
Here's what I used:
First - get to the brake rotors and then get them off: Then trim the spindle duct
to fit. Then attach the hose, clamp it on to the spindle duct, the clamp it in spots to the arm - you'll need to test the proper slack in the hose by moving the steering wheel fully left-and-right to make sure there is just enough to reach. Then cut a hole in the plastic shroud just to the left and right of the radiator - place the vents just behind the grill and through the hole - attach the duct hose. The finished product:
This area is intended for Tech Tips submitted by members of LincolnvsCadillac.com. The opinions expressed here are the opinions of the individual author and do not necessarily represent the views of LincolnvsCadillac.com. Undertake these procedures at your own risk. If you have any comments or questions please contact the individual authors. Reader assumes all the risk associated with the installation of aftermarket products. LincolnvsCadillac.com and its owners are not responsible for any direct or indirect damage to the vehicle, person or persons and the resulting costs incurred from the installation or use of these products. LincolnvsCadillac.com recognizes that "Cadillac" and "Chevrolet" and their respective logos, model names and numbers are registered trademarks of the General Motors Corporation. These and other terms used on this website are used for identification purposes only. Lincolnvscadillac.com is not affiliated in any way with the General Motors Corporation, Cadillac, Chevrolet, Mobil or any other website or company listed herein. |
