      The latest modification I have
        performed is a complete coil spring conversion to my 1994 Lincoln Mark
        VIII. I had performed the common "sensor lowering" to my car
        and exposed a leak in the right front air strut. After close inspection,
        I discovered that all four of my 10 year old air bags were showing small
        leaks.
      The following information will
        provide you with a basic description of the modification along with a
        few pictures of the job. I also decided to install a 1.5 inch lowering
        kit to achieve the handling and look I desired.
       To
        remove the Lincoln Mark VIII stock air strut, first I relieved the air
        strut of air by removing the solenoid. Then I proceeded to un-hook all
        the air ride hardware. Next, I removed the upper control arm from the
        knuckle, removed the lower control arm-to-strut bolt, and unbolted the
        top nuts from the air strut. I was then able to drop the air strut out
        of the car.
      To remove the stock air strut,
        first I relieved the air strut of air by removing the solenoid. Then I
        proceeded to un-hook all the air ride hardware. Next, I removed the upper
        control arm from the knuckle, removed the lower control arm-to-strut bolt,
        and unbolted the top nuts from the air strut. I was then able to drop
        the air strut out of the car.
       The
        kit came with both air suspension struts completely assembled with springs.
        After taking this picture, I completely removed the factory air ride height
        sensor, and solenoid, and then neatly wire-tied all the wire connections
        behind the inner fender cover. That way they would be kept safe out of
        the way of the air suspension components, and they will remain on the
        vehicle incase I ever decide to re-install new factory air suspension
        components
      The rear part of this job is
        quite a bit different. The rear air bags are mounted separately from the
        shock. The air bags are held in place between the lower control arm and
        the rear carrier. The bottom of the air bag has a 4-point clip-in design,
        and the top of the bags are held in place by a twist-lock method. You
        must support the lower control arm with a third-man jack.
       Release
        the air in the rear air bag by removing the solenoid. Then, loosen and
        remove the lower shock mounting bolt and remove the rear sway bar link
        pin. Next, press in each of the 4-point clips that hold the bottom of
        the air bag to the lower control arm. Once each of the clips has been
        released, slowly lower the control arm until the lower part of the air
        bag is free from the lower control arm. Next you have to rotate the air
        bag until the twist lock is free from the carrier frame. Remove the bag
        from the car.
      The next step is to install
        the rear springs. Each spring should have a flat end where the last 2
        coils come together to form a flat surface. This is the TOP of the spring.
        There is a spring pad included in the kit. The spring pad has a stud sticking
        out of the top-center of it. This stud is used to center the pad in the
        top of the old air bag mounting location. The bottom of the spring has
        a blunt-cut coil end. You MUST line this cut end up in the rectangular
        cut out in the lower control arm's air bag cup (where the air bag was
        mounted). This rectangular cut out is there to ensure you properly match
        the installation of both rear springs, so the ride height will be equal
        on both sides.
      Raise the third-man jack until
        the lower shock mount bolt is lined up with the hole location. Keep an
        eye on the spring to make sure it has not rotated in the spring cup. Install
        the lower shock bolt, and the rear sway bar link pin. Make sure you have
        safely removed all of the air suspension components, and wire-tied all
        the extra wires and lines securely out of the way.
      I decided to replace the rear
        shocks at the same time. I also replaced the rear upper shock mounts.
        I recommend you do the same if you are installing a coil-spring kit. The
        ride characteristics are very comparable to the factory air ride with
        the exception of the SELF LEVELING feature. To obtain the best possible
        ride from this conversion, I recommend replacing the rear shocks since
        the front struts are new. I am extremely pleased with the quality of parts
        in this kit. There are a few different conversion kits available, such
        as from American Air Suspension.
      That's it. Let the car back
        down, and be sure to hand-torque your lug nuts back on. I also recommend
        that you check your tire pressure. That way your test drive will produce
        true results!
      Don't be surprised if your
        Lincoln Mark VIII sits a little higher than expected at first. The springs
        are new, and have yet to support any weight. They will settle within a
        few hundred miles or normal driving. I also recommend that you have a
        4-wheel alignment performed after the air suspension settles. My Lincoln
        Mark VIII sits exactly 1.5 inches lower than the stock ride height after
        250 miles of normal driving.
      I recommend this conversion
        to anyone who has been dissatisfied with the factory air suspension on
        their 1993 - 1998 Lincoln Mark VIII. Many Lincoln Mark VIII owners love
        their factory Lincoln Mark VIII air suspension ride, and will never change
        it. Just be advised that there are options out there. This is one of them,
        and you will NOT be disappointed!
