First off, you
NEED a 96-98 Cobra fuel pump. The non-Cobra units do not have the
same style of pickup tube, and will not work. The Cobra specific units
do not cost anymore than the non-Cobra units.
Here is what the
stock fuel pump assembly looks like when you remove it from the fuel
tank.
.JPG)
Remove the 5 5mm screws from the lid. 3 hold the lid to the basket,
2 hold the fuel feed and fuel return lines to the lid. That leaves
it looking like this.
.JPG)
Undo the stock
wiring connector, leaving the pump in the basket. This is what you
will have then.
.JPG)
Pull the pump
out, at this point it is not attatched to anything, so it just comes
out. Remove the fuel sock from the bottom of the pump. It just pulls
off. On the top of the stock pump, there is a rubber isolator about
3/4" tall on the pump itself. Remove that and put it on the Walbro
pump. It is a TIGHT fit, you will have to massage it on there but
it will fit, its a stretch. I put the stock fuel sock onto the new
Walbro pump as mine was not overly dirty seeing as how my stock pump
had been replaced along the line. That will leave you new pump that
looks like this.
.JPG)
Drop the new pump
assembly into the basket.
.JPG)
Test fit the lid
back on the basket with the Walbro in the basket. You will find that
the lid does not seat all the way down like it did with the stock
pump. Like shown here.
.JPG)
.JPG)
The fix for this
is easy. Go ahead and remove the lid again, leave the pump in the
basket. Flip the lid over and look at the area where the fuel pump
protrudes through the lid. There is a circle of plastic that keeps
the pump in place so that it does not move around in the basket. This
needs to be shortened to accomodate the slightly longer Walbro pump.
.JPG)
Take a grinding
tool of some sort, Dremel or mini air die grinder, whatever you have
available, and whittle away at the circle until you remove enough
material so that you can get the lid to sit flush on the basket and
still hold the pump in place. You will find that the rubber isolator
you took off the stock pump and placed on the Walbro pump fits nicely
inside the circle, making a nice seal. Try to get the depth of the
plastic as close as you can to make a good seal, but its not overly
critical. The isolator takes up difference as much as it can. Here
is a pic of how I modded my lid. Note I left the plastic mess on it
to show the removal of plastic. Clean yours well and remove all plastic
dust and debris before reinstalling everything.
.JPG)
Now you are ready
to put it all back together. Take the 5 screws and reattatch the lid
to the basket with the new pump inside. Now its time to take a look
at the electrical side of things. Compare your stock fuel pump wiring
to the pigtail connector supplied in your kit.
.JPG)
Try putting the
stock connector in the pump, and you will see that the shoulder of
the connector does not allow the connector to sit deep enough in the
fuel pump to engage the locking tab on the stock connector. Looking
back at the pigtail supplied in the kit, notice that the shoulder
of that connector is about 3/16" (give or take) higher than your
stock one. Take and trim off enough of the shoulder on the stock connector
to allow the plug to sit deep enough in the pump to engage the locking
tab. I used a sharp carpenters knife to trim my connector, a dremel
would do the trick, just be careful not to trim too far into the plug
and hit the wiring.
.JPG)
Plug the modded
stock wiring back in the pump, and your done!
.JPG)
Here is your finished
unit.
.JPG)
As with all mods,
do this at your own risk. I (or Lincolnvscadillac.com) cannot be held
responsible for information within. The process might vary slightly
from car to car, this is just an overview.:
