Transmission Fluid and Filter ChangeLincoln Town Car |
Changing your own transmission filter can be scary, but once you get into it, it's really not that difficult. If your are experiencing slipping or other major fault with your transmission, you should take it to a dealer or trusted transmission shop for an examination as the Lincoln Town Car has a highly technical transmission. |
Tools and parts you will need: Safety glasses Note: wear safety glasses while under the vehicle for eye protection as there's lots of dirt and grime under there just waiting to drop into your eyes. The new filter and gasket. I used the filter brand Fram model FT1167. The fit was good.
Drive your Lincoln Mark VIII onto the ramps. Put a block of wood or equivilent behind the back tires. Wait until the vehicle has cooled off for at least 1/2hr if you've just driven it to avoid getting a "hot oil treatment"... burns hurt! Be Careful! The transmission fluid will likely still be hot! Don't burn yourself! Remove the rubber inspection grommet (1 1/2inch diameter) between the Lincoln Mark VIII engine and the transmission in the bottom of the bell housing. Use a flathead screwdriver to pry it out - not difficult. With an assistant
under the vehicle looking into the inspection hole with a flashlight or
worklight, use the 18mm socket & wrench to turn the crankshaft pulley
(by the radiator) to turn the engine (clockwise). In the inspection hole
you will see the torque converter. Have your assistant stop you turning
the engine when the 11mm drain bolt is visible in the torque converter.
You can do the procedure yourself but it is a lot of climbing under the
vehicle and back to turning the crank pulley until you find the plug.
Place your drain pan
under the inspection hole and remove the drain plug out of the torque
converter with an 11mm socket and extension. The oil will pour out slowly...
in fact it may take a couple hours to fully drain the torque converter.
It is estimated that it holds almost half of the transmission fluid capacity
or around 6 quarts. Replace the drain
plug and tighten securely but do not over-tighten. Some people like to
use locktite on the threads to prevent it coming out. This is difficult
unless you let it drain overnight so you can clean off the plug and dry
off the threads in the torque converter. If fluid is still dripping out
it will be difficult. It's optional! Ok, then after tightening the plug,
replace the inspection cover. Loosen all the bolts
holding the Lincoln
Mark VIII transmission
oil pan on. Carefully remove the bolts by one corner of the pan. Carefully
pry the pan down at that corner with your drain pan underneath. There
will be fluid going everywhere. Try to get a drain pan that is at least
18 inches wide. Keep removing the other bolts but leave them loose on one edge to hold the pan up. Tilt it more to get more oil out. Once half of the oil is drained hold the pan back up with an assistant if you have one and remove the rest of the bolts while your assistant holds the pan up. Then carefully drop the pan (without spilling fluid all over yourself) into your drain pan. Drain it.
Here's a picture of the Ford 4R70W transmission pan with the gasket sitting on top. The OE gasket is re-usable and is stamped as such shown by the red arrow on the right side of the picture below. Notice the grey colour donut magnet shown by the arrow on the top left of the picture.
The transmission with the pan off.
Using rags or paper towels and solvent clean the interior of the pan and carefully remove the sludge from the pan magnet at the bottom. Clean the edges of the transmission that the gasket touches. A rag or your scraper might be needed to get any rubber that's stuck on. This surface must be clean to allow a good seal when you put the transmission back together. Clean out the transmission pan and remove all remaining parts of the rubber gasket around its edges. There is a metallic film on most of the pan surfaces that will wipe off. If you find a little plastic plug with a rubber o-ring, don't worry, this was in the dipstick tube while the engine was assembled on the assembly line and falls into the transmission pan. It's not a broken or missing part! Discard it or keep it as a souvenier.
The clean transmission pan. Don't lose the round magnet that's in the bottom of the pan! It goes on the little bump and it collects any metal shavings that might be floating in your fluid. Take it out and make sure it is clean.
Note
the position of the OE filter, pull it off and replace it with the new
one, make sure the old rubber seal comes out too. Pop the new filter in
place of the old one in the same position. Use clean rags to clean the
gasket mating surfaces on the pan and the transmission. The old gasket
is re-usable. Place the pan back up onto the transmission. Hand-tighten
all the bolts. If you
have a torque wrench use it to make sure you don't over-tighten the bolts.
Using
a long funnel fill about 5-6 quarts into the transmission through the
dipstick tube. You'll need a small neck funnel. Start
the engine. With your foot on the brake, slowly move your gear shifter
to each position, leaving it in each position for about 10 seconds before
moving to the next. Shut
the car off and fill another 4 or 5 quarts. Start
the engine again. With your foot on the brake, slowly move your gear shifter
moving to the next. Put car
in Park and let the car run for about 10 mins. Then inspect the fluid
level with the dipstick. Fill
more oil up to "full" mark on dipstick. Drive your Lincoln Mark VIII around the block and check the transmission fluid level. Mine took just a hair over 12 quarts. Capacity if the transmission oil cooler/lines where empty as well is listed at 13.5 quarts for the Lincoln Mark VIII.
Cost: $105.00 (approximately) 13 quarts
Castrol Mercon V semi-synthetic $5.00 per qt - $65.00 for the job
Many transmission shops do a "power" fluid change by hooking up to the cooler lines and doing a pressure fill/exchange without dropping the transmission oil pan. This isn't the best since you have old fluid mixing with new, and you haven't changed the filter. As well the magnet in the pan won't get a cleaning and won't work as effectively to catch metal sludge/particles out of the oil. Think of a power flush as taking a shower, then putting your dirty clothes back on. Not exactly ideal. Do it
yourself, then you'll know it has been done right! Take pride in your
Lincoln Town Car.
This area is intended for Tech Tips submitted by members of LincolnvsCadillac.com. The opinions expressed here are the opinions of the individual author and do not necessarily represent the views of LincolnvsCadillac.com. Undertake these procedures at your own risk. If you have any comments or questions please contact the individual authors. Reader assumes all the risk associated with the installation of aftermarket products. LincolnvsCadillac.com and its owners are not responsible for any direct or indirect damage to the vehicle, person or persons and the resulting costs incurred from the installation or use of these products. LincolnvsCadillac.com recognizes that "Cadillac" and "Chevrolet" and their respective logos, model names and numbers are registered trademarks of the General Motors Corporation. These and other terms used on this website are used for identification purposes only. Lincolnvscadillac.com is not affiliated in any way with the General Motors Corporation, Cadillac, Chevrolet, Mobil or any other website or company listed herein. |
