the1calledgod
Hi everyone. I've been on this site alot, and my account got deleted from not using it enough. Well here is the deal. I have a 94 mark8 w/82k on it. My rear air bags have a leak (did the ole leak test myself and it leaks at the folds). Im thinking i want to do away with the whole air system, and just go with a nice tight shock setup. I took my mark to the lincoln dealer and the inspected everything under the car.
things they said i needed.
L-R Wheel Bearing (2.5 hours?)
Front Inner Tie Rods \
Front left outer tie Rod / (3.0)
Both sway bar end links (1.0)
Both Upper Ball Joints (4.0)
Rear Air Springs
So my question is...... Can I replace these things rather cheap going with non-air shock supsension???? and how big of a Bit@# is it to replace all this front end bullsh^%? I got new tires at walmart cause they were open late. and they didn't turn the air suspension off.... So now my car drives like a air hover craft... scares the shi% out of me to drive it over 60mph.
Thanks for everyones help! It will be needed. I just hope I don't have to rap my mark around a tele pole cause it isn't worth anything.....
Rear Air Springs
