RigsLS
- Joined
- Mar 10, 2012
- Messages
- 7,756
- Reaction score
- 532
BigRig, there is no e in Mobil 1.
There is no #4 in the name Mark either.
---- EDIT: I myself got rid of a slight ticking (not marbles) by replacing RP oil with Mobile1, then further switched it out to 0W20 M1.
... The Marvel will clean out the lifters in case there's any residual gunk in them. No guarantees, but this is a very cheap possible solution that may help solve the problem.
I'm still thinking pinging or cat, more to cat now.
You have the V6 correct?I'm having a similar issue, I'm not sure if I'd like to ride on the back of the phrase marbles and such, but I do have a noticeable ticking/rattling coming from the engine bay when at WOT or going up a hill and a few other situations. I was thinking of taking it in to the shop to have the secondary cam tensioner checked as I've seen referenced on many articles but not really sure I should just start with that as I'm sure it's expensive labor just to have them look at it. I also had this after the oil was changed and still have the noise after all new coils/plugs. Any thoughts?
V6's are not known to have any timing chain/tensioner problems.
Ah ok, yes I do. Thanks Joe. Do you know of anything else that might cause this for my model? I was just thinking it was something simple as cosmetics since one of the front cowls does not have anything anchoring it down.
Bad tank of gas? I didn't see anything about 93 octane. Can you get it in your area? Some performance tuning raises the octane requirements. If you can't get 93, add some octane increaser and try it again.
I wouldn't run 0-20 oil,but that's your choice. don-ohio^)
I hope it's that simple for you.Let us know your outcome,okay? don-ohio^)
dang, got got by the inlaw... Lol
i would have sent his ass out to the drive way with a hose and told him to suck that cheap sh!t out!
