First off, let me back up when i replaced my egr valve. I replaced it with a advance auto BWD brand, not motorcraft.
Right after putting it in, my trans wouldnt even go into 1st gear. It would creep slowly no matter how much gas i push down.
Let me say, this wasnt all the time. It would randomly display E on the dash, then give me this creeping effect. I'd say 2 times a week so it wasnt fully destroyed yet.
When i crank the car up i can here a whirr in the front lower part of the car, its a slight buzz that goes on for like 30 seconds or so, and it only does this when the trans errors.
I got to where i figured out how to get it into 1st by gassing it to 20-30mph then brake. I could then hear the trans shift down once or twice, then the E would goto D5 and i could drive the car normally.
As of today its going into E more often, once a day now. If i can get the car trans reset back to D5 before hitting the busy roads i'm good, but driving it around like this is dangerous.
No problems with the trans before until that day i replaced the egr, and right after i installed it and cranked it up the trans was borked. Coincidence, or does the EGR have something to do with the trans??
Also, EGR errors are back, so either i got a junk egr or its all tied together. Before i take it to a shop i wanna at least know how to talk to the mechanics so as to not get screwed or overcharged. I'm thinking solenoid pack of course, but if its the egr i can replace with a motorcraft this week no problem. Then again it could all be an electrical issue, wouldnt surprise me especially with my message display going crazy, beeping, showing weird errors, and not turning off like it should.
heres the error code list. Any help is appreciated.
I didnt think the ls would start having trans issues at 110k miles, i barely drive this car.
Current Fault Log
P0403: Exhaust Gas Recirculation Control Circuit
P0443: Evaporative Emission Control System Purge Control Valve Circuit
P0446: Evaporative Emission Control System Vent Control Circuit
P0743: Torque Converter Clutch Circuit Electrical
P0755: Unknown code - More information may be available on the web
P0760: Shift Solenoid "C"
P0962: Unknown code - More information may be available on the web
P0966: Unknown code - More information may be available on the web
P0970: Unknown code - More information may be available on the web
Pending Fault Log
P0750: Shift Solenoid "A"
P0765: Shift Solenoid "B"
Historic Fault Log
ECU reports no historic faults
Other discovered fault codes
(possibly pending, current or manufacturer specific)
P0731: Gear 1 Incorrect Ratio
P0740: Torque Converter Clutch Circuit
P0748: Pressure Control Solenoid "A" Electrical
P0753: Shift Solenoid "A" Electrical
P0758: Shift Solenoid "B" Electrical
P0763: Shift Solenoid "C" Electrical
P0768: Shift Solenoid "D" Electrical
P0778: Pressure Control Solenoid "B" Electrical
P0798: Pressure Control Solenoid "C" Electrical
P1572: [Chrysler] ASR Active Circuit Low Too Long
[Dodge] ASR Active Circuit Low Too Long
[Jeep] ASR Active Circuit Low Too Long
[Seat/Audi/Volkswagen] Left Eng. Mount Solenoid Valve Short to ground
End of report.
Current Fault Log
Pending Fault Log
Historic Fault Log
End of report.
