Lincoln vs Cadillac - Do It Yourself Car Repair   Cadillac
Lincoln vs Cadillac Forums - - - LVC Tech Articles Home
Cadillac CTS-V Exhaust
3" Race X-Pipe Cat-Back Installation
 cadillac cts performance exhaust
Submitted by: StealthV
Videos:
X-Pipe Cruising around Town
X-Pipe Motoring Down the Interstate (with prototype StealthV CAI)
Use this as a pictorial reference only; always refer to the official B&B PErformance Exhaust instructions for more detail or clarification.
For more information, please visit  B&B Performance Exhaust
Installation time:  Approximately two leisurely hours with one person.
  1. Items/tools needed:
    1. 1 set of Rhino ramps
    2. 1 set of jack stands (or second set of Rhino ramps)
    3. Hydraulic floor jack
    4. Trouble light
    5. 1-pound hammer
    6. Rubber mallet
    7. 11/16" wrench
    8. 17 mm wrench
    9. 16 mm wrench
    10. ½" drive ratchet
    11. ½" extension
    12. ½" drive, 16 mm socket
    13. 3/8" ratchet
    14. 3/8" extension
    15. 3/8" drive, 13 mm socket
    16. 3/8" drive, 15 mm socket
    17. 3/8" drive, 16 mm socket
    18. Pry bar
    19. Drift punch
    20. 12 pack of Dew ;-)
    21. scrap wood 2x4s
    22. Zaino Z6 (or equivalent for clean up prior to engine start)
    23. Microfiber towel
2.  Open up the B&B Performance exhaust box and admire the beauty of polished stainless!
3.  Compare your hardware included with the kit to the bill of materials on the B&B installation drawing.
Cadillac CTS V
 4.  Oooo..x-pipe!
Cadillac CTS V
5.  Support the rear of the Cadillac CTS V on Rhino ramps.  Jack up the front and support the front of the Cadillac CTS V with jack stands (or another set of Rhino ramps).
6.  Loosen the four nuts most of the way at the two front flanges of the factory exhaust, do not remove the nuts yet.
7.  Remove the two bolts holding the center cross brace.  Remove the center cross brace.
Cadillac CTS V
 8.  Place a 2x4 on the head of the floor jack, roll the jack under the rear of the Cadillac CTS V.  Line up the 2x4 under the exhaust just in front of the differential.  Raise the 2x4 up until it just contacts the exhaust.
Cadillac CTS V
 9.  Slide the rubber muffler hangers off.  The hanger shown is towards the front of the muffler.
 10.  The two hangers at the rear of the muffler are already removed in this photo.
Cadillac CTS V
11.    With the 3 rubber hangers removed on each muffler, slowly lower the floor jack.  After the jack has been lowered all the way, finish removing the four front exhaust flange nuts.
 12.  If you've placed the 2x4 in the position shown, the factory exhaust will be perfectly balanced and can easily be rolled out from under the car with the floor jack.
Cadillac CTS V
 13.  Oooo..balanced.
performance exhaust
14.  Attach the two front B&B pipes to the factory exhaust manifold down pipes, using the metal gaskets in between.  Only start the nuts onto the studs at this time, do not tighten.
Cadillac CTS V Cadillac CTS V
15.  Slide the two clamps over the x-pipe.  Make certain to orientate them such that the nuts are pointed down when installed on the car.  Then slide the x-pipe under the car.  Note the orientation of the center sheet metal tabs that are welded to the x-pipe.
 16.  Slide the x-pipe over the front pipes.  Make sure to fully seat the x-pipe over the front pipes.
performance exhaust
 17.  Support the rear of the x-pipe - I used a 12-pack of Dew and a 2x4 on edge.  =)  Use a 2x4 and a hammer to seat the x-pipe over the front pipes.
performance exhaust
18.  Line up the center support on the x-pipe with the two holes in the underside of the V's body.
Cadillac CTS V
19.  Install the B&B performance exhaust supplied bushings (two thick & two thin) and bolts into the center support.
Cadillac CTS V
 20.  The thinner of the two bushings is on top.
b b performance exhaust
 21.  Place the mufflers under the Cadillac CTS V.  With the six rubber muffler hangers off the car, lubricate the holes (I used a squirt of Zaino Z6).  Install the three rubber muffler hangers on each muffler.  Next, lift the muffler up into position and slide the front muffler hanger over the hook on the car.  Then slide the two rear hangers onto the Cadillac CTS V's hooks.  Repeat for the second muffler.
 22.  Line up the muffler pipes with the x-pipe.  Place paper gaskets between the flanges and install the two nuts and bolts in each.  Snug each side of the flange up evenly and tighten.
Cadillac CTS V performance exhaust
23.    Prepare for the unveiling. Performance exhaust!
Cadillac CTS V
 24.  Look at those 4.5" tips on the Cadillac CTS V Performance Exhaust.WOW!
 25.  Make sure to tighten the four bolts at the muffler/x-pipe joint first.  Next, tighten the front four exhaust flange bolts at the front of the car.  Next snug up the center support bolts and finish by tightening the clamps at the connection of the x-pipe and front pipes.
 26.  Before starting the engine, wipe down all surfaces of the exhaust - mufflers, tips, pipes to prevent blemishes and fingerprints from being burned in, discoloring the surface of the stainless.  For mine, I used a microfiber towel and Zaino Z6.
Photos after 6 good heat cycles and 100 miles later....
performance exhaust Cadillac CTS V performance exhaust
Cadillac CTS V performance exhaust performance exhaust
 performance exhaust Performance Exhaust!
This area is intended for Tech Tips submitted by members of LincolnvsCadillac.com. The opinions expressed here are the opinions of the individual author and do not necessarily represent the views of LincolnvsCadillac.com. Undertake these procedures at your own risk. If you have any comments or questions please contact the individual authors. Reader assumes all the risk associated with the installation of aftermarket products. LincolnvsCadillac.com and its owners are not responsible for any direct or indirect damage to the vehicle, person or persons and the resulting costs incurred from the installation or use of these products. LincolnvsCadillac.com recognizes that "Cadillac" and "Chevrolet" and their respective logos, model names and numbers are registered trademarks of the General Motors Corporation. These and other terms used on this website are used for identification purposes only. Lincolnvscadillac.com is not affiliated in any way with the General Motors Corporation, Cadillac, Chevrolet, Mobil or any other website or company listed herein.
