In these directions
you will find out how to install an Edelbrock nitrous kit
in your Hot Rod Lincoln. I do not tell you how to put
together your solenoids. Because that is a step that you should read in
your edelbrock nitrous instructions. I might not go in an order that you
might choose to. That is fine. You can go any way you would like. I started
like this. . .
Step One:
My solenoids have
already been put together and I was looking and looking for a place to
mount them. I could not find a spot that I really wanted to mount them.
After just looking at the engine bay for several days. I decided to mount
them on my Mac cold air induction. That takes air from the fender. If
you have seen this intake before. You will notice that there is a very
good flat piece. That goes up against the inside engine bay, to cover
the whole that goes to the fender.
So, I decided I would
mount my solenoids there. I took the mounting bracket that came with the
nitrous kit and put it up against the fender intake. I have decided to
mount it on the far corner on the panel. Before I started drilling. I
took masking tape and put it on both sides of the intake panel. The reason
I used masking tape is so the chrome would not chip and it is also known
to make the edges clean after you drill through metal. I put the mounting
bracket back onto the intake and marked my holes with a marker.
I started with a 9/64"
drill bit. After I made my holes with that bit. I went to the next bit
and the next one. Till I got to 7/32" drill bit. That was my final
bit. I used about two sizes between them bits. Reason being, it's just
what I do. It makes for cleaner holes. You have to go to the Hardware
Store for your bolts, washers, etc. They do not come with the kit. I made
my holes a little bit bigger then the bolts I used.
Shopping
List;
Three (3) Black Hex Bolts 10x1/4" (Size/Length)
Three (6) Washers 10 (Size)
Three (3) Lockers 10 (Size)
Three (3) Nuts 10 (Size)
After I got everything
I needed at the store along with some Mtn. Dew (OS1). It was time to mount
it up. I first mounted the solenoids to the bracket. (Just easier on you
to do it now.) Then I put it up against my mounting holes. I'm mounting
my bracket with three bolts. Because the bracket allows me to. Two bolts
should be enough. (I'm safe then sorry.) I went with one hex bolt, one
washer, bracket, intake plate, one washer, one lock washer, and then bolt.
(In that order) I just tightened it down till the lock washer was flat.
(That was for all three) After you have done your first step. Step back,
take a look at what you did. Get a Mtn. Dew! Take pride, that you have
done a great job!
Step
Two:
This will be an easy
step for you to do. It is going to be running your nitrous feed line form
your solenoids. (Solenoids to Bottle) Now you have to make sure your nitrous
solenoids are mounted. Take one side of your nitrous lines and screw it
onto one of your solenoids. (The side that is feeding your system.) You
can now take the other side of your nitrous line and start feeding it
through your engine bay. Getting it down to the bottom of your floor boards.
Make sure you use zip ties to keep your line secure. I fed my line where
the metal fuel lines go down the car. Hooking my nitrous line with zip
ties every foot or so.
Now that you have
gone down your car and zip tied every foot or so. It is time for you to
feed your line into the car. I found a rubber garment at the very back
of the back seat. It is a perfect place. Because you do not have to dill
into the body and rust could happen. So, you should drill a ½"
hole. Depending on your line. It may need to be bigger or smaller. Because
you want the rubber to fit tight against the line. You do not want to
make it bigger then the line. Because water can then get in. (Tight against
the line is best)
I
have now fed it through my hole in the car and can decide where my bottle
needs to be mounted in the trunk. If you would have done this step first,
would your line have reached your bottle or would you be buying longer
nitrous line? (Better safe then sorry)
Instead of getting
in the trunk after you were just on the floor. (Tight spot to tight spot)
Let's go mount the wiring harness. That is step three for me. But first
lay back and check your line/zip ties. Cut off any extra that there might
be. (Zip Ties) Make sure you have enough slack in your lines for body
movement. Also, make sure what you did is good enough for you. If not,
it doesn't hurt to re-do it your way!
Step Three:
This article is going
to be about mounting your Wiring Harness for your edelbrock nitrous kit.
You should keep in mind where you mounted your solenoids and where your
wires need to go. (Such as switches and solenoids.) In my mind set. I
am looking to keep things very clean and not able to notice them in one
glance. In this mind set I am willing to extend wires and nitrous lines
if needed. Because it is about clean looking for me.
My first thought was.
Where am I going to mount the 30 amp relay and fuse holder. I wanted to
put them where I can get to them easily. Just in case. (Remember, better
safe then sorry.) I found a great spot near the solenoids. And there were
a bunch of holes already there. So, I decided to use two of them. (This
is great, because you do not have to drill into the body and expose metal
for rust.) Taking some drill bits. I put one in each hole. To see what
they're sizes are. So, I can go buy some bolts, etc. My sizes ending up
being ¼" and 7/32". I got my bolts a little bit smaller
then the holes. So, I can use nuts. Now it is time for shopping!
Shopping
list;
One (1) Hex Bolt 10
One (1) Hex Bolt 8
Two (2) Washers 10
Two (2) Washers 8
One (1) Locker 10
One (1) Locker 8
One (1) Nut 10
One (1) Nut 8
I needed at the store. Along with some Mtn. Dew. (OS1, by now I ran out.)
It was time to mount them. Here is where it paid off to mount my wire
harness near the solenoids. As you can remember I mounted my solenoids
on my intake plate. Well, I can take off the intake and I am able to reach
through to put the nuts on. If you can not put nuts on. You will have
to use sheet metal screws. I really like to use nuts and lockers. It makes
for a very tight fit. That should last forever! Well, I went with one
hex bolt, one washer, harness/fuse holder, sheet metal/body, one washer,
one locker, and one bolt. (In that order) I did this to both of them.
Now step back. Look
at what you have done. Is it what you want? Take pride in what you have
done. You are almost there to be able to run nitrous on your Hot Rod Lincoln!
But not before you mount your nitrous bottle.
Step
Four:
Now before you hop
in the trunk to install your Edelbrock nitrous bottle. Get your bottle
and brackets. Put your brackets on your bottle. (Where you want them.)
Tighten everything down. If you are going to run a bottle heater. The
brackets will have to be so far apart. I think it is 8 ½"
from bracket to bracket. You will have to have at least 1" from your
first bracket to the bottom of the bottle. (Do not go any closer to the
bottom of the bottle.)
Now here are some
of the things your should have before you hop in. Bottle with brackets
installed, marker, masking tape. Now hop in and put your nitrous bottle
where your nitrous line can reach. Before marking the wholes it is always
good to use masking tape when drilling through metal. Put the tape down.
But your bottle back where you want it. Now mark your holes. Get out of
the trunk. Take everything with you. Now you will need a drill and drill
bits.
But it isn't that
easy. It's measuring and measuring. Because you need to bolt it from the
bottom. I took off my rear tire and measured and measured. The frame goes
right down my bolt holes. If you drill into the frame you will not be
able to bolt it. So, make your holes count! After you have the holes drilled
with a 3/8" drill bit. It is shopping time. Remember you will need
grade 8 bolts and etc. I used one size smaller bolts/etc then the 3/8"
drill bit. . .
Shopping
List:
Four (4) Grade 8 Bolts
Eight (8) Grade 8 Washers
Four (4) Grade 8 Nuts
Now all you have to
do is. Stick the bolts down from the top. My order was one bolt, one washer,
bottle bracket, floor board, one washer, one nut. After you have done
this. Take a good break. I know my hands took a beating trying to get
them nuts screwed on. You will need a friend to help you out. Someone
has to hold the top bolt while you torque the nut down. I had my very
helpful wife Dannielle help me out.
Step Five:
On this step I am
getting you out of the trunk and to a much easier step. Installing your
sprayer nozzle. Now keep in mind. You should take this step carefully
and slowly. Do not rush through this step. Now that we got that out of
the way.
My nitrous instructions
said to drill a 7/16" hole for my nozzle. I had a few places I wanted
to put the nozzle already. I really wanted to put it into my Cobra Manifold.
But now knowing. You have to have it before the throttle body. Because
that is where my nitrous switch is located. (At W.O.T. my nitrous
will spray.) So, you have to have it before your switch so the nitrous
can shut down in time.
So, after I have already
mounted my solenoids on my fender part of the intake. I thought I would
just mount my nozzle on that same piece. Just so, all the nitrous components
are just messing with one piece. Just incase I decide I do not want the
nitrous anymore.
I choose to mount
my nozzle on the bottom part on my intake pipe. I do not want a direct
view of the nozzle. I also, wanted it to look cleaner. Plus, there is
plenty of room under there for the nozzle to stick out.
Now I first put the
intake back in the car and choose a spot. Putting my fingure on the spot
I want it. I took the intake out. Then put masking tape where I was going
to drill. I then marked with marker on the masking tape. Now it is time
to drill. But just wait. I put the intake tube back in the car and checked
where I put the masking take. I made sure that it was in the spot I wanted,
still. (You never know, better safe then sorry.) The first drill bit I
used was 13/64". Then I used one between that and ¼"
for my final whole. Now that I have my hole drilled straight and true.
It
was time to tap the whole. (Put threads in.) They should have given you
a tap that is the perfect size for your nozzle. (Yours can be different.
So, check your Edelbrock nitrous instruction book.) I put the tap in the
whole and with a wrench to match the top of the tap. I slowly started
to turn it. Making sure it was going straight in. It is okay to stop and
look into the tube. (Do not pull out tap. Just leave it in.) Keep going
slowly and check in tall you have got to the end of the tap. (Do not go
all the way to the end.) Now you should slowly back out your tap. Making
sure to keep your threads true
Before you install
your nozzle. Clean the whole with a rag. Or blow into it. Making sure
it is clean. Now you can install your sprayer nozzle. It should go in
very smooth, like butter. Now take a break. Remember take pride that you
did it. But don't take to long of a break. We are almost done with a nitrous
spraying Mark VII!
Step Six:
In this step we will
get our feet wet with electrical. This being the nitrous gauge. I used
a Autometer 4728 mechanical gauge. With a Autometer carbon fiber gauge
pod 2121. I also needed some nitrous line. With 16 gauge wire and connectors.
I used male and female connectors. So, I can easily remove the gauge.
I
started with mounting my gauge cup. I mounted mine on the passenger a-pillar.
You can mount it where ever you would like. Its end less. . . After I
mounted the cup. I got my line and put it through the cups rear. Then
screwed it onto the back of the gauge. When putting the gauge in. You
will have to have the female connectors already on the rear of the gauge.
(For the lighting.) After you have put the gauge in the cup. You will
have to make up extra electrical wire to reach where a power source is.
Make sure it is a source where there is no power when the key is not on
the ON position. After you have hooked your electrical wires up and everything
is tied up with zip ties.
Now it is the time
to run your nitrous gauge line to the bottle. Or you can have it hooked
up by the solenoids. I choose to hook it up on the bottle. Instead of
making a hole in the fire wall. . . Do not put the trim pieces over the
nitrous line. Because you will have to check the line for leaks when you
arm your system for the first time. (Soapy water and a brush.) Now that
you have finished your gauge install. It’s on to the next step!
Step Seven:
This step should
be very simple. It is mounting your activation switch or Go Baby Go Switch!
Now I have a switch that sprays the nitrous at full throttle. If you just
have a button. It will be even easier. But I will not cover that! This
is about installing the Edelbrock nitrous kit.
Now
first it comes with a bracket you can bend. Because this is kind of a
universal kit. I starter with just taking a look around the throttle body
area. Keeping in mind. It can not get in the way of any other parts. (Throttle
cables or near heat.) Before you start bending the bracket back and forth.
Just size it up. Make sure it will work. The last thing you want to do
is make the bracket weak. (By bending it back and forth.) Use some scrape
metal or card board.
I ended up mounting
my bracket on the lower right bolt. (One of four bolts that hold the throttle
body on.) I had a great advantage because I am also installing a new Ford
Racing Cobra Manifold with an Edelbrock TB. So, I was able to do this
outside of the engine bay. It will be a little harder doing it in the
engine bay. The big thing is to have it click at wide open throttle. Not
before then. So, take your time to get it right. Make sure you can hear
it click. If it does not click. It will not activate the nitrous. So,
once you tighten it down. Open the throttle a few times to make sure it
still clicks and that’s all there is to it!
Step Eight:
This step is too
easy to make a step. But it is an important one. This will be mounting
your fuel regulator. You first have to take off the pressure restrictor
on the fuel rail. This is located by the intake tube going down the engine.
While you screw it
off. There may be fuel in the rail. So, hold a rag under it. So, it will
not leak all over the engine. Now that you have gotten it off. You will
need to take the adapter piece that came with your regulator and screw
that on first. Once that is tight. Take your regulator and screw it on.
You are finished.
Make sure you can get to the power and ground screws when you do the wiring.
Now on to the next step!
Step
Nine:
This step we will
be installing the fuel jet and T fitting. You will need to unplug the
vacuum line from the rear of the upper intake. The one that leads from
the intake manifold to the fuel regulator.
Now with you “T”
fitting. You will need to run a line from the Bottom “T” opening
to the rear of the manifold.
The bottom part of the “T” fitting is the one side that holds
the fuel jet. It also the part that unscrews. Now once you have done that.
Take the line you took off in the beginning and run it from the Right
side of the T sitting to the fuel regulator. Now the last part. Will be
to run a line from the Left side of the T fitting to the nitrous fuel
regulator. (Nitrous regulator that sits just under the nitrous solenoids.)
Once you have all
lines tighten down. You have finished step nine. One more thing, I took
a zip tie and tied the T fitting to a rubber hose. So, I can easily change
out the fuel jet. You might want to do the same and also install the jet
you want.
Step 10:
This
is you final step. This will include wiring and the switch to turn on
the nitrous. Let’s first find a stop to install the switch. I put
mine on the center console. I just popped. But you can put your switch
anywhere you want. Once you have mounted yours. Let’s start on the
wiring!
I first started with
the wires on the solenoids. The first one has two wires. One to the ground
the other to the harness. I cut them down to length and put some male/female
connectors on the wires. The second solenoid has two wires also. One goes
to the harness and the other goes to the fuel pressure switch that you
put on the fuel rail. On both solenoids, the one that goes to the harness.
You have to connect together and connect them to the blue wire coming
from the harness.
Now let’s wire
up the throttle switch. The black wire that comes from the harness has
to connect to the middle
opening of the switch. Now you have to put a ground on the opening that
is on the right side that is on the side of the switch.
We will now have to
wire up the switch in the car. That activates the system. You have to
drill though the fire wall and run the white wire to your switch location.
After wiring the white wire to the switch you will need to install a ground
to the switch. After you have done that. There is one more line. A power
line. You may want a line that only has power on the start position of
the key. I just used the line (Power& Ground) from the cig lighter.
Since I don’t have a cig lighter anyways. Once you are done with
that. You will need to put any trim back on if you had to take any off.
Now is the last step.
Running the MAIN power line to the nitrous. It is a red wire coming from
the fuse holder that is part of the harness. Once you have wired that
up. You are now DONE! You may want to take all the wires away in loom
or something. Just make sure everything is tied up out of the way!
LAST
CALL:
Before spraying you’re
nitrous for the first time. Read your instructions. They may ask you to
do something after your first spray. If you are having problems while
running your nitrous. Check back in your Edelbrock nitrous instruction
book for problem solving. Have fun! This is the easiest horse power you
will ever get.
P.S. You will have
to fill up your Edelbrock nitrous bottle. . .
