Engine Thermostat ReplacementLincoln Mark VIII |
1. Drain coolant level below upper radiator hose and thermostat housing. 2. Disconnect lower radiator, coolant recovery and engine return hoses at thermostat housing, then remove two thermostat housing retaining bolts. 3. Remove O-ring seal and thermostat from thermostat housing. 4. Inspect O-ring for damage and replace if necessary. 5. Reverse procedure to install.
Tighten to 7-8 ft lb .
This area is intended for Tech Tips submitted by members of LincolnvsCadillac.com. The opinions expressed here are the opinions of the individual author and do not necessarily represent the views of LincolnvsCadillac.com. Undertake these procedures at your own risk. If you have any comments or questions please contact the individual authors. Reader assumes all the risk associated with the installation of aftermarket products. LincolnvsCadillac.com and its owners are not responsible for any direct or indirect damage to the vehicle, person or persons and the resulting costs incurred from the installation or use of these products. LincolnvsCadillac.com recognizes that "Cadillac" and "Chevrolet" and their respective logos, model names and numbers are registered trademarks of the General Motors Corporation. These and other terms used on this website are used for identification purposes only. Lincolnvscadillac.com is not affiliated in any way with the General Motors Corporation, Cadillac, Chevrolet, Mobil or any other website or company listed herein. |
