How to Repair The Tilt Telescoping Steering Column in your Lincoln Mark VIII |
Submitted by: Eric1 |
I am writing this for the 2nd Gen, but the procedure should be similar for the Gen 1 First before you do anything go to your dealer and purchase the potentiometer, part number F7LZ14A605AA. This step will minimize the down time. It's about $30.00.
LIST OF SUPPLIES. Before you do any removal or unscrewing make sure to disconnect the battery.(I know you are saying yah yah yah but this time id do it as your are playing with the wires that control the airbag). First, reach under
the dash and remove the 2 black bolts that hold the cowl on under the
steering wheel of your Lincoln Mark Viii and gently pull it off. Now you should have full access to the bolts holding the column in. reach down to the steering knuckle and with your 10mm socket remove the crimp bolt from steering knuckle (its locktited in so you need some force) then reach under and locate the 4 nuts holding the column in place. Using your 13mm socket remove these four nuts again locktited and hard to turn. After all of this is done you should have this in your hands, and this in your car ok get up stretch and go to a nice work table on and btw you'll see this when you look back. Don't worry it's worth it. You should be about 40 minutes into this job.
You should now have this. Now you should notice that you have 2 distinctly different sized cable screws. Put a socket on the larger of the 2. Slowly begin to turn the ratchet as if you were removing a bolt you will notice your column is beginning to extend continue on slowly until you are left with 2 pieces. Don't worry about the splines they too are keyed. Remove and inspect the ball bearing and replace as needed. Remove tracks and clean all the old grease out from everywhere you can. Now with the tracks and bearings out and everything clean brush a healthy layer in the groove and then lay the track back in and add more grease to the track. Clean off any excess. Now once again use your T-20 Torx and remove the long black box this is the reason we are here. Make sure you do not lose or break this piece it's the tab for the slider. You will notice a space for this in the housing. Ok take a break your are now half done. Now reinstall the potentiometer in its area. Go back to you 2 pieces and rejoin them slowly making sure not to catch the bearing retainers on the housing. Also make sure you a perfectly straight when you put the threaded rod into the hole for the telescope. Reinstall the top plate make sure you tighten the screws in an opposite pattern (like when you put on a tire) and don't forget the locktite. After that reinstall motors and sensor. And then you should be able to reinstall it into the car. I hope this helps you out any questions just ask.
This area is intended for Tech Tips submitted by members of LincolnvsCadillac.com. The opinions expressed here are the opinions of the individual author and do not necessarily represent the views of LincolnvsCadillac.com. Undertake these procedures at your own risk. If you have any comments or questions please contact the individual authors. Reader assumes all the risk associated with the installation of aftermarket products. LincolnvsCadillac.com and its owners are not responsible for any direct or indirect damage to the vehicle, person or persons and the resulting costs incurred from the installation or use of these products. LincolnvsCadillac.com recognizes that "Cadillac" and "Chevrolet" and their respective logos, model names and numbers are registered trademarks of the General Motors Corporation. These and other terms used on this website are used for identification purposes only. Lincolnvscadillac.com is not affiliated in any way with the General Motors Corporation, Cadillac, Chevrolet, Mobil or any other website or company listed herein. |
