Lincoln Town Car Power Antenna Mast Removal and Installation |
Car washes can be hard on the fragile power antenna mast in the Lincoln Town Car. However, it is relatively easy to replace and not very expensive. Antenna masts can be found frequently on Ebay for between $10 and $20. This procedure also applies to most Lincoln Automobiles. |
Tools: -Needle Nose Pliars
With needle nose pliers, insert nose into slots on nut at top of antenna base.
Remove nut and base from antenna mast. Turn car stereo on, remove antenna mast and nylon cable by pulling from power motor assembly.
Remove two plastic side panel tabs from panel.
Pull side panel from car, feeding manual gas flap release through panel.
Disconnect antenna
cable and connectors from power antenna assembly. Remove bolts securing
power antenna motor assembly. Place antenna motor assembly on flat ground for disassembly.
Remove cover from power antenna motor assembly.
Remove gear assembly. Turn car stereo one,
allow power antenna to cycle, feed nylon cable into antenna and turn car
stereo off.
This area is intended for Tech Tips submitted by members of LincolnvsCadillac.com. The opinions expressed here are the opinions of the individual author and do not necessarily represent the views of LincolnvsCadillac.com. Undertake these procedures at your own risk. If you have any comments or questions please contact the individual authors. Reader assumes all the risk associated with the installation of aftermarket products. LincolnvsCadillac.com and its owners are not responsible for any direct or indirect damage to the vehicle, person or persons and the resulting costs incurred from the installation or use of these products. LincolnvsCadillac.com recognizes that "Cadillac" and "Chevrolet" and their respective logos, model names and numbers are registered trademarks of the General Motors Corporation. These and other terms used on this website are used for identification purposes only. Lincolnvscadillac.com is not affiliated in any way with the General Motors Corporation, Cadillac, Chevrolet, Mobil or any other website or company listed herein. |
