Round numbers:
8000: Purchase price last july.
150: Two 15,000 LB GVWR Stack Plate Transmission coolers
600: Griffin Radiator - Can't find anyone else who can custom build me one. suggestions are welcome.
1000: 94 Teksid Block
2400: 298 c.i.8.5:1 CR Forged Rotating Assembly
3100: Heads. Int/Exh Lift .450 - duration 215@50..? Exh 220@50thousands . Lobe 114 degrees. I'm sure the head guys know what this all means... if I even wrote it down properly that is.
200: New timing chains, tensioners and sprockets.
800: New accessories, like WP, AC compressor, Alternator, PS pump and pulleys.
600: 96-98 Cobra Intake
300?:SCT Mega Meter
31oo: Twin Turbonetics 60 Series Hair Dryers with a .61AR - this may change -
700: Kook's Headers - Long bung FORD O2 sensors
40?: Cobra High Volume Oil Pump
200?: ARP in all the right places
650: Aeromotive Fuel Rails
200: BEGi RRAFPR (Rising Rate, Adjustable Fuel Pressure Regulator)
850: 72lb/hr Matched High Impedance RC Engineering Injectors
345: Three Walbro 255 lph/HP Intank Pumps -
600?: Racer's Edge 3200 Stall Converter - this will have to be restalled once the package is done -
2500: Bauman Engineering tranny with lock-up
650: Denny's MMX Driveshaft
200: Carrier Brace
500: Ford Racing 3.73 Trak Loc Gears + labor
650: Raxles Halfshafts
200?
olyurethane Bushings
180: Cobra Bilstein Shocks
300?: Front struts from eddie
120: R&P Assembly
300: Addco Swaybars
???: 5x4.5 Mustang hub conversion on all 4 corners
1600: 13" Crossdrilled/vented PBR Dual Caliper Brakes on the front
Stock size cross drilled/vented brakes on rear.
1000: ASA AR1 18" wheels. Black with machined lip.
1000: Eagle F1's wrapped on the wheels
600: NGS Tester
299: X-Cal 2
900: Panasonic Toughbook for datalogging.
900: Avic D1+XM NavReaffix receiver.
600: Remote start/alarm with labor
500: ApeXi Turbo controller.
700: Brand new Driver's side Door Panel.
400: Valentine One Radar Detector.
I'm going to add another grand for various stuff like custome PS lines, nuts blots and the like.
Bitch of it is, It's still not done.
