Nothing much stock for now on the LS!
F150 - 1997 - 2WD F150 Mods:
DJM Suspension 4" front 6" rear drop (Just kept it sporty!)
S-10 - 1990 S-10 Mods:
Fully Juiced 10 Switch HiJacker Hydraulics
2 Pumps, 4 High flo Dumps (one per wheel)
6 Batteries, 3 per pump.
(No its to long to bust those cool 3 wheels you see in the videos, however you can make a right turn, drop the drivers front corner, and left the passenger wheel off the ground on the turn! (reverse 3 wheel!)
89 fiberglass camero hoodscoop molded into an steel s10 hood
Reverse mounted rear cylinders, no cylinders in the rear, custom axel mounts pointing them downwards and out of the bed.
Brand new 4.3 Vortec
Fully molded and smoothed body line (GONE!)
Cowl vent closed shut, welded down and wind shield wipers shaved in.
Fully molded one piece rear-end
Shaved tailgate handle also molded
Custom frenched antenna in back rear corner with electric antenna
Ran out of room, i'll post a site with more info!
