'00 Headlight Wiring Diagram
Krishna
Canada
I'm trying to wire up my CCFL rings and am a bit confused. I did a search and came up with:
"If you want to pre-wire the angel eyes to your parking lights you will need to tap the hot (+) wire from the ballast to the Orange/Blue wire from the OEM wiring harness. Then tap the ground (-) wire from the ballast to the Black/Blue wire from the OEM wiring harness. After that just plug in the wires from the rings into the connectors from the ballast."
First problem is that I have two Black/Blue wires connected to my signal (signal is the same as parking light?) and the second is there is no orange/blue wire I only have a pink/blue one. The pink/blue one is connected to "GRD" and the other black/blue wires are connected to "MINOR" and "MAJOR". Which wires do I tap into? :confused:
Any help would be greatly appreciated. Thanks in advance!
Does your headlights have the city light feature? I have only seen this on one other LS. I actually have a set of the city light headlights for the LS. However, since you have two black/blue wires just tap into one of them and if it doesn't blink when you turn on your turn signals you should be good to go.
