003 Deville dts trouble codes
purelux
2003 Deville warning problem?
P0386. And p0340. Its for the camshaft and crankshaft sensor. I'm looking at buying the car and wasn't sure if this was a big or expensive problem to worry about. The seller says he thinks it came up after he had the battery replaced.
I now own the car, checked and cleared the codes, only drove a few miles but so far the check engine light hasn't tripped again. However I have a warning to check coolant level, I figured it was just low. However I checked and the coolant is nearly to the top of the resevoir. Does anybody know if the sensor can tell if the coolant/water mix is off or if it just checks the amount of coolant.
