streetwise83
i have an 02 ls 3.9L v8 w/ 95,000 mi. was driving the other day car ran fine got on the highway to merge and it started missing/ surging feeling. after a few minutes check eng. light came on. code was p306 missfire cyl 6 so i changed all the plugs and the coil on #6 cyl. car stills has a mis only seems when engine is warm and at higher speeds. any ideas?? also i found oil in spark plug wells 1.2.3.4.5 the rest were dry i havent done the new valve cover gasket they r on order could the oil in there be causing a mis??
