infamous amos
I am in the process of replacing the clutch on my 2002 Lincoln LS V6 with a manual transmission. I began my clutch replacement project with the EXEDY KLN01 OEM Replacement Clutch Kit. Upon visual inspection, the components appear nearly identical. However, when I went to install the new pressure plate I found that the pressure plate and flywheel did not mate completely flush. The replacement pressure plate is slightly different than the original as photographed below:
A representative from Exedy has told me "[are you] reusing the OEM used dual mass flywheel? This is required to be replaced whenever doing a clutch job on this vehicle, it is a non re-usable part. The new OEM flywheel may be a revised version which fits this clutch kit."
Now, my question is; where should I purchase the flywheel? Will any replacement flywheel work with this Exedy clutch kit? Has anybody already done a clutch replacement on their LS? I am probably going to take the new clutch kit to the dealer today to see what they say. I guess this is what I get for trying to save a few bucks.
Any insight is greatly appreciated.
