Have a 06 and a 02. 5 days ago, the 2002, gave me a lights, and message center, Warning that's says- Check Traction, Park Brake Dash light, and ASB Light Dash light.
4 days ago I reset the Battery (disconnect), and also found the Brake Fluid was a little low. I added the Fluid and the light went away.
Yesterday I found I had some very Premature worn Front Brake pads and one of the Caliper pins was stuck a few days ago. I installed new front Rotors and Pads and fixed and greased the stuck Brake Pin.
Been driving the car around all day today, and when I started it this evening to drive off again the warning beep message center went off again - Check Traction, Park Brake Dash light, and ASB Light Dash light.
Anybody had this problem and/or know what it is? Thanks!
