Remove exhaust
Remove driveshaft
Drain gas tank
Remove rear subframe
I'm going out on a limb here ...is the 2006 2nd Gen EVAP Canister Vent solenoid set up differently than the 1st Gen? In the 2006 Lincoln LS Workshop manual it doesn't look like the tank needs to be dropped? My other question ... Is the Evaporative Emission Canister Vent Solenoid accessible to get to without removing subframe on the 2006 LS? I have the P0455 code and might have to dive into replacing these components? Here is the two diagrams from the 2006 LS Workshop ....
Printable View (86 KB)
Material
Item Specification
Motorcraft SAE 5W-20 Premium Synthetic Blend Motor Oil
XO-5W-20-QSP (in Canada Motorcraft SAE 5W-20 Super Premium Motor Oil CXO-5W20-LSP12) or equivalent WSS-M2C930-A
Item Part Number Description
1 14A464 Evaporative emissions (EVAP) canister vent solenoid electrical connector (part of 9L468)
2 9E616 Fuel vapor tube
3 9F945 EVAP canister vent solenoid
Removal and Installation
WARNING: The evaporative emission system contains fuel vapor and condensed fuel vapor. Although not present in large quantities, it still presents the danger of explosion or fire. Disconnect the battery ground cable from the battery to minimize the possibility of an electrical spark occurring, possibly causing a fire or explosion if fuel vapor or liquid fuel are present in the area. Failure to follow these instructions can result in personal injury.
WARNING: Do not smoke or carry lighted tobacco or open flame of any type when working on or near any fuel-related component. Highly flammable mixtures are always present and may be ignited, resulting in possible personal injury.
WARNING: Do not carry personal electronic devices such as cell phones, pagers or audio equipment of any type when working on or near any fuel-related components. Highly flammable mixtures are present and may be ignited. Failure to follow these instructions can result in personal injuries.
- Disconnect the battery ground cable. For additional information, refer to Section 100-02 .
- Disconnect the evaporative emissions (EVAP) canister vent solenoid electrical connector.
- Disconnect the EVAP hose and remove the EVAP canister vent solenoid.
- NOTE: Make sure the electrical connector harness is correctly routed.
NOTE: To ease installation, lubricate the inside of the EVAP hose with clean engine oil.
To install, reverse the removal procedure.
- Carry out the evaporative emission system leak test. For additional information, refer to Evaporative Emission System Leak Test in this section.
- Carry out the evaporative emission repair verification drive cycle. For additional information, refer to Evaporative Emission Repair Verification Drive Cycle in this section.
SECTION 303-13: Evaporative Emissions
2006 Lincoln LS Workshop Manual
REMOVAL AND INSTALLATION
Procedure revision date: 06/24/2005
Evaporative Emission Canister Printable View (145 KB)
1 — Fuel vapor tube quick connect coupling (part of 9E857)
2 14A464 Evaporative emissions (EVAP) canister electrical connector (part of 9L468)
3 14A464 EVAP canister electrical connector (part of 9L468)
4 W503925 EVAP canister bracket assembly bolts (4 required)
5 9E857 EVAP canister assembly
- With the vehicle in NEUTRAL, position it on a hoist. For additional information, refer to Section 100-02 .
- Disconnect the battery ground cable. For additional information, refer to Section 414-01 .
- Remove the rear subframe. For additional information, refer to Section 502-00 .
- Disconnect the fuel vapor tube quick connect coupling. For additional information, refer to Section 310-00 .
- Disconnect the 2 evaporative emissions (EVAP) canister electrical connectors.
- Remove the 4 EVAP canister bracket assembly bolts and the EVAP canister and bracket assembly.
- To install, tighten to 9 Nm (80 lb-in).
- To install, reverse the removal procedure.
- Carry out a leak test. For additional information, refer to Evaporative Emission System Leak Test in this section.
