NascarGuy
Been a forum member a good part of a week and spent most of it reading the forums concerning the gremlins I face with my LS8 but have not found all the answers yet so figured I would make my first post.
Purchased the LS8 about 3 weeks ago. It is an '02 with 101k miles on it. It had the usual misfiring issues as well as a few others so after reading around I spent a good part of yesterday replacing the valve cover gaskets, plugs, and coil packs which made a huge difference. I no longer have the misfire or hesitation issue but still have one that I thought this tune-up would eliminate. The car is still slow to start when it is cold; slow meaning that I have to turn it over for 10 to 15 seconds before it will fire up. Once running, it runs like a dream and once warm it starts fine. After completing the parts swaps yesterday I also disconnected the battery to clear all codes and then reconnect. I drove around for a bit then took the car to AutoZone to see if any new codes were in the system. Presently I do not have any engine lights or codes showing. Any help with this issue would be appreciated. Lastly I have to mention before I did the tune-up yesterday the car was also a PITA to start. It would take the same 10 to 15 seconds to finally catch.
Thanks in advance and thanks for all the great info.
