Archer28
No charge on anything due to it still being under warranty, but I'm curious about the "water into the cap wells" TSB that is cited.
If anyone remembers I had the car go into failsafe, and it was missing.
The note on the invoice reads: (not corrected for spelling)
VERFIED MISS IN VEICLE PERFORMED IDS SELFTEST FOUND CODE P0304 CK OASIS AND FOUND TSB 05 16 0 2 VERFIED WITH TSB THAT WATER WAS GETTING INTO THE CAP WELLS AND HAD DAMAGED THE NO 4 COIL PACK PERFORMED TSB PROEDURES REMOVED COILS AND CLEANED BOOTS BLEW THE WELLS DRY AND APPLIED DIELECTRIC COMPOUND INTO THE BOOTS OF THE COILS REINSTALLED COILS AND INSTALLED TWO VENT COIL COVERS REMOVED COWL PANEL INSTALLED NEW FOAM SEAL REINSTALLED COWL TEST DROVE CERTIFIED FIX
The invoice shows one DG*515*coil asy-ignition
and two XW4Z*12025*AD cover- ignition coil
Its running fine now (still such a great car to drive).
Just wanted to post for a FYI!
