remove the radiator cover, remove the bulbs on the top of the housing, then the housing should be semi loose. It will be stuck on the outside part of the fender. Grasp the headlight housing firmly on both outer sides and give it a nice tug. It should pull right out. Then remove the headlight access panel, low beam should be 9006 unless factory equipped with HID.
