Gus_Mahn
How long does it typically take to pull the intake on a second generation 3.9 v8? I think I have a vacuum leak and have bought the o-rings off ebay to seal the lower to upper.
Thank you. Doesn't look bad at all. Any experience separating the lower and upper to change the o-rings?An hour if you are in a hurry, two if taking it easy and it's the first time (for you).
http://deneau.info/ls/s6x~us~en~file=s6x31006.htm~gen~ref.htm
