gytwypt
Alright I have done the searches and havent found exactly what I am needing.
Passenger side is questionable : I dont believe the front passenger side is coming up all the way and the back passenger side is definetly not coming up all the way. I put it in 4wheel drive low side to exagerate the lift. The pump is coming on and shutting off after the driver side achieves the height.
Since the pump is kicking off does this mean I have ride height sensor problems? If so is there a way that I can check this out or do I have to give the stealership $96 just to look at it. That is what I was quoated to just look at it and if it needs recalibration it is another $45, and who knows how much if the sensor is bad.
any help please
thanks
Joe
any help please
thanks
Joe
