Where are you located?? A hood for $50?!?! Im all over that if your not too far! Whats up with the engine?
Alax you're converting a gen 1 front end into a gen 2 front end correct? Make sure you get the header panel the gen 2 headlight mount to. Also IIRC they use a different connector than the gen 1 headlights, so you might want to grab the connectors too.
If you could get me a price on the door sills that would be awesome. Front and rear.
Thanks!
I'd be interested in the ABS Pump and computer too.....again Thanks!
Alax, I could REALLY use the OEM speaker plugs - all 4 of them. This is part of the factory wiring in the doors that has the plugs that go directly onto the speakers. I would need about 5 - 6" of wire with each plug.
Thanks in advance for checking on this!
TRU
That is why whenever I buy replacement speakers, I buy the adapters too. Your local audio shop whould have them.. They connect direct to the speaker, then on the other end, they have the correct end to mate up with the factory plug. makes for a very fast installation, and going back to stock is even faster.
Just FYI for next time.
I want the passenger's side rear view mirror if they're the folding ones if it's not too much trouble. Also what color is the interior?
