In July my coolant outlet housing (big chunk o plastic behind the thermostat) sprang a leak on the way home. RockAutoed a Gates CO34838 Coolant Outlet kit which includes the full front and back housing with a new thermostat. Swapped it out and spent two days trying to get the system to bleed correctly. I followed the bleed procedure over and over, and every time I thought I had it as soon as I would take it out on the road it would start overheating within a few blocks. I've swapped all of the plastic cooling system components at least once since I have had her (some parts multiple times) so I'm pretty familiar with the process, but never had this much trouble before. I thought for sure I had a crack somewhere else, but on a whim I swapped back in the front plastic piece of the housing that contains the thermostat from the old housing, and that took care of it instantly. I've put a several hundred miles on it since then with no issue. I'm not 100% sure the new thermostat was the issue. What I'm wondering is if what may have happened is there was still air in the block which acted as a buffer and never caused the thermostat to open? I've read recently that some folks (other cars) will drill a very small hole in the thermostat to allow water to flow through to help the bleed process. Has anyone had success doing this on their LS thermostat?
