10th Anniv. calipers
KC96LSC
Kansas City
I just purchased 10th Anniv. calipers, what rear calipers do I need? I know I also need the adapter kit, could someone tell where to get them. Also what is the correct rotors to purchase? Am I correct that I will need to have someone redrill the rotors for the mark bolt pattern?
Thanks for any information.
Greg
you need 99+ cobra rear rotors, 11.65". you can use your stock calipers.
you need 94+ cobra front rotors, 13"
here is the guy you need to talk to about the brackets.
http://forums.tccoa.com/showthread.php?t=37231
you haev 2 choices, you can swap hubs to fit the brakes, and but new wheels, or you can redrill the rotors to the mark pattern. you can even buy predrilled rotors from diskbrakesrus.com
