2 Quick Things.
Iwantmymarkback
bellmore
Hey guys, two quick little things. If anyone could help me out that would be great.
Okay Number one, My airconditioner seems to be on the fritz. Yes I said on the fritz. When I put the setting on vent it comes out, but not hot, nor cold. When I put on MAX AC or I put the fan all the way up, It doesn't kick on. One night It kicked on for a second, then turned off. Any suggestions?
Number two, My message display center often just starts to say Drivers Door Adjar. My door isn't adjar. Is this a sensor error? or is the computer just stupid? Is this a big to-do or is it just something simple?
Thanks again guys.
-Rick
The issue with the A/C sounds like something to do with the plug on the blower motor. You need to pull out the glove box to get to that.
And the issue with your door being ajar, spray WD-40 onto the metal striker(little metal bar) that the door latches to. That should take care of that.
Try searching for the A/C thing.
EDIT: Here is the A/C problem right in our tech articles.
http://www.lincolnvscadillac.com/tech/lincoln-mark-viii/blower-motor-repair/index.htm
spray the wd into the latch the switch is in the botton of the latch then slam the door a few times it will fix it for a while then it will be more often then replace the switch i do it everyday on hundreds of fords
The WD-40 did the trick.
I wish I could say the same for my a/c. I tightened them... nothing, then I went into my 94 and took that one out, and put it in, nothing. Maybe something bigger?
-Rick
