20 inch tires for my 20 inch rims.. help!
lisupremelegacy628
new york
i have 20 inch rims for my 2002 lincoln ls i had 245/35/20 tires on them ...what other tires can i fit on them with out a rubbing issue or other problems please help asap im looking for tires as we speak...thanks to all
dude knock it the hell off, you dont have to make more than one thread asking the exact same question in one hour, tires made for F150's will not fit on an LS
You should probably get some 20" wheels for those rims.
If you don't understand the fundamentals of tire specifications you shouldn't be buying "rims" for your car.
theres the problem, you've jumped the gun. you got it all wrong, you should wait to look at tires until you know what size to look for first.
My problem with both of his threads is there isnot nearly enough info to actually give advice. Wheel width and offset? Stock ride height or lowered?
