20% Off Optimum including ONR!!! (exp 1/25)
Detailed Image
Albany
20% Off Optimum
20% off ALL Optimum products including ONR!!! Stock up for your winter detailing and hose free washing!
Weekly Special! - FREE Aerospace Protectant! - 16 oz with coupon code WSAEROS0312 (Minimum Purchase: $60 Expires: 1/24/12 11:59 PM EST)
303 Aerospace Protectant
16 oz Price $12.99
32 oz Price $22.99
128 oz Price $57.99
  • An excellent UV protectant and dressing for vinyl, leather, rubber and plastic surfaces
  • Leaves behind a beautiful matte finish that is not greasy, shiny or oily
  • Treated surfaces resist dust, soiling, staining and also repel water
  • Most commonly used on interior dashboards, center consoles, door trim, leather seats, and in the engine bay
  • Works great on vinyl convertible tops, plastic rear windows, clear bras, and tonneau covers
  • For maximum efficiency use in a 4oz pump spray bottle and apply with a microfiber towel
January Monthly Specials!
DI Microfiber Waffle Weave Drying Towel
Regular Price for 36" x 24" is $17.99. Sale price is $12.99!
  • One of the best options for drying your vehicle and most commonly used by professional detailers
  • The waffle weave texture helps pull contamination away from the surface compared to a flat chamois
  • Our microfiber waffle weave towel has silk edging to minimize adding imperfections
  • This towel can hold up to 5 times its weight with water
  • We recommend using the sheeting method prior to drying with the towel for maximum efficiency
  • Always wash your microfiber products prior to first use
Dodo Juice Born Slippy Clay Lube Concentrate
Regular Price for 250 ml is $12.99. Sale price is $9.49!
  • Ultra concentrated solution makes for over 2.5 liters of clay lube
  • Dilute up to a 10:1 ratio with water while remaining super slick
  • Wipes away streak free and is safe for nearly any surface
  • We recommend picking up a 22oz spray bottle for proper dilution
Thank you for checking out our deals, if you have any questions or need product recommendations please do not hesitate to ask!
Greg @ DI
