So like I do each summer I refil the ac with 28oz r134a but this time it leaked right out as i was putting some in slowly,, i read it can be the scroll oring or something but i cant find the correct part online thanks
Hi, Taking off the intake is not as hard as you think. Suggest you take 6 pictures of it from the rt and feft side, get a book too, mostly its removing long bolts , 10 or so, disconnect anyrthing still attached to intake. Advise taking more pictures after you remove bolts. Easiest was I found is to remove the hood with the help of a friend. makes seeing everything easy. Get new intake gaskets, cean up intake head ports and intake manifold ports rel clean Use a small wire brush in a electric drill, cover up the head intake ports as not to get filings into the motor. Then using new intake gasketys assemble it after you get the a/c hose problem fixed. Takes about 4 hours to do it 1st time It is not that hardWell I took another look at the a/c hoses today and the place where I think was leaking doesn't leak , it looks like it was sheared but its just a imperfection.
after an hour I finally found the leak and its right under the 3 metal coolant hoses that runs on the passenger side on the body right in front of the head .
its the one wrapped with a insulation wrap of some sort, Its in a very tight spot looks like one would have to pull the engine lol..
thinking how the hell im going to put the new hose in myself. Too expensive to bring the thinng at a shop
Try some Super seal by AC pro, its for 134. repairs metal leaks, seals rubber leaks. Coats is 25.00 thru amazonSo like I do each summer I refil the ac with 28oz r134a but this time it leaked right out as i was putting some in slowly,, i read it can be the scroll oring or something but i cant find the correct part online thanks
I feel like you are not talking about an LS...Hi, Taking off the intake is not as hard as you think. Suggest you take 6 pictures of it from the rt and feft side, get a book too, mostly its removing long bolts , 10 or so, disconnect anyrthing still attached to intake. Advise taking more pictures after you remove bolts. Easiest was I found is to remove the hood with the help of a friend. makes seeing everything easy. Get new intake gaskets, cean up intake head ports and intake manifold ports rel clean Use a small wire brush in a electric drill, cover up the head intake ports as not to get filings into the motor. Then using new intake gasketys assemble it after you get the a/c hose problem fixed. Takes about 4 hours to do it 1st time It is not that hard
Funny you suggest this because on one of my LSes I used some leak seal on the AC system before taking it to a shop to have it properly filled and its held up for 10 years now of course I thought it would either fail miserably....knowing it would be at best a bandaid I was planning on permanently fixing it but you know what they say if it's not broke don't fix it ...still can't believe how cold the AC blows every summer still...but if you can change the hose I would definitely replace itTry some Super seal by AC pro, its for 134. repairs metal leaks, seals rubber leaks. Coats is 25.00 thru amazon
No, it's not necessary. Just saying that I would do that before I removed the engine. I haven't done it, but the service manual says you can get to that AC connection with the engine in and the intake on.Yeah its a pretty big leak so some sealing stuff probably wont do much.
So is this possible to do without taking the head off?
@joegr you said remove the intake manifold but is that necessary I don't see why I should remove it.
I tried searching for a diagram of the hoses or a manual for the procedure but did not see any on deneau or google. thx all
Its worth 25.00 to find out, you save all the labor and cost if it works. I wou;ld give it a try before I removed the intake manifold.Yeah its a pretty big leak so some sealing stuff probably wont do much.
Until it clogs or sticks the TXV and you have to pull out the whole dash to replace it...Its worth a try
Does that bulb work with the hazard 4-way flashers running?Yeah I never even thought about trying stopleak lol.. I need a diagram
I dont want to start another thread but now my driver side front blinker dont work only the park lights up i goy multiple new bulbs and same thing i checked the FEM stuff and fuses they all good
I get 11.88v on the harness will forscan rule this one out? Lol my ls is literally tearing apart rn
I tried but no it does not work and even when I press the lock / unlock on the fobDoes that bulb work with the hazard 4-way flashers running?
It can't hurt to pull power from the battery terminal for a half hour or two and see if it persists.I tried but no it does not work and even when I press the lock / unlock on the fob
it’s a walk in the park on gen 2 anyway.I feel like you are not talking about an LS...
