MarkVIII93
Would a 26x10.5" tire fit on a 15" fan blade t-bird wheel? They're on some pretty skinny chevy wheels right now. maybe 15x7.
Yes, those are the exact tires. I was pretty sure that they would fit. But id like to make sure before i go and have them mounted. Considering that these tires require tubes.... could I just get them mounted at the local tire shop?MediumD said:These tires?
http://store.summitracing.com/partd...921520+4294793325+4294854796+115&autoview=sku
The minimum reccomended rim width is 7.3" - you could probably get away with a 15x7 but I'd try to stick to the reccomended specs.
MarkVIII93 said:could I just get them mounted at the local tire shop?
10.5'' MT ET STREETS will fit no problem but I don't think that 10.5 MT ET DRAG will fit on 15'' fan style t-bird wheel--they are 15x6.5.I have 27x11.5'' MT ET STREETS on fan style wheels and they fit no problem.My brother has 26x8.5 ET DRAG on fan style wheels and the width is preatty much same as mine.If you aren't planning to run lower than 10 psi on slicks don't even waste your time and money with tubes.I've got my slicks without tubes for about 4 months now and they still hold an air.Here are few pictures of my 27/10.5/15 MT ET STREETS on fan style t-bird wheels vs 255 BFG drag radials on super coupe 16'' wheel.If you want to see T-bird fan style wheels with MT slicks mounted on 98 mark VIII check this video Click here to see VideoMarkVIII93 said:Would a 26x10.5" tire fit on a 15" fan blade t-bird wheel? They're on some pretty skinny chevy wheels right now. maybe 15x7.
Thanks a lot man. You really eased some worry off my shoulders. I thought that tubes would be neccessary. I plan on running 15-20 psi.95sc said:10.5'' MT ET STREETS will fit no problem but I don't think that 10.5 MT ET DRAG will fit on 15'' fan style t-bird wheel--they are 15x6.5.I have 27x11.5'' MT ET STREETS on fan style wheels and they fit no problem.My brother has 26x8.5 ET DRAG on fan style wheels and the width is preatty much same as mine.If you aren't planning to run lower than 10 psi on slicks don't even waste your time and money with tubes.I've got my slicks without tubes for about 4 months now and they still hold an air.Here are few pictures of my 27/10.5/15 MT ET STREETS on fan style t-bird wheels vs 255 BFG drag radials on super coupe 16'' wheel.If you want to see T-bird fan style wheels with MT slicks mounted on 98 mark VIII check this video Click here to see Video
Derek
