3.0 v-6 supercharger?
nope.
the issue is not getting a supercharger - there are all over the place.
the issue is making a intake manifold that matches your heads, allows for the proper placement/re-routing of throttle, cooling hoses and fuel rails - with the proper mounting for the SC and fits under the hood.
the bigger issue is to make sure SCT has your PCM code in their 'cracked' database or you will not be able to tune your engine after adding the SC and the project stops there.
