Hello,
First of all I'm at the point where I'm debating selling my lincoln or keeping it. I've got a LS 2000 with about 140K.
Skill Level - I've about 0 knowledge with fixing cars, an oil change I could probably handle, even managed to find the battery hiding in the trunk (cough after 20 min cough).... I'm not horribly inept with other fixing tasks like dishwashers etc.
Problems
Problem 1) When I first start the car, if I put it in gear and drive at anything more than grandma pace, I will more likely than not hear a high pitch whine coming from the front of the car (likely a fan? Is that the coolant fan?). The whine increases as soon as I touch the gas and decreases if I let my foot off it. I can litterally watch the temperature guage rise if I do anything other than take my foot off the gas (and then it might be slightly creeping up).
Assuming I drive slow, after about 5 min, I can drive regularly and have never had a problem. Also if the problem does occur, I can stop the car, wait 5 min, and the problem is usually gone.
Question: Am I right about it being the fan? That Fan cools the engine somehow... does it cool the coolant, which cools the engine? Is the car really over heating?
What Steps should I tell my mechanic and approx how much cash for each? If the problem is inconsistant, It's a bit hard to verify after each of the steps if the problem is gone... advice?
1) "bleed the coolant system" (I guess you top it up afterwards...
2) Check this Degas bottle thing to see if it is cracked, sounds like it needs to be removed....
3) There is a solenoid valve I read about and a thermostat... are they the same thing? Are they the next step to be replaced?
4) More....
Problem 2) - Transmission. It takes a good 3 or 4 seconds to switch into neutral or reverse. Also in fifth gear at about 80km/h I notice some juttering. I used to drive standard, and it feels sort of like engine braking a bit. Is there a common transmission issue? Recommended fix?
Problem3) Parked the car, went into store, came out, engine won't turn over. Just a little click from the back left section of the engine (if your at the front of the car looking towards the windshield. I figure it's the starter. Mechanic agreed and is fixing starter for 300 bucks (can), apparently part is 199 plus tax. Saw some online for 65 bucks or something.... That seems a lot of difference in price on a part... thoughts? Good place to buy lincoln parts in Canada?
Problems
4) More....
