turborich
Well after reding some post on here about the 40 below product being the best thing to use for helping to cool the engine down I figured that I would try it. We did it to (2) mark VIII's at the same time and followed the directions exactly. All I can say is that it didn't do anything! Doesn't run any cooler at all. I used distilled water and everything like it called for. IMO this stuff is junk! It's been around 115 degrees here and both of the marks are running warm in the day time. Getting up to the (N) on the gauges. Both of them! It seems that this is about 235-240 at the engine. I used a handheld infrared thermometer to find out the temp at the front of the engine near the water pump. All I can think of is that the high ambeient temps are just too much. The heat radiating off of the ground is around 160-165 degrees. Does anyone eles live in the desert where it's 110+?? how hot does your mark run? Also the radiator fans are working properly, the cooling systems are clean and there is NO air in the system.
