Im goin with the 40 series muffler for the 03-06 LS. anyone know the size? center offset etc. i dont know what that means. does anyone know the size and offset the car needs? (only replacing the mufflers)
'00-'02's were 1 7/8" or 2" inlets into the mullfers... I think the 03+'s were a bit larger but not sure. Measure the diameter of the pipe right before it enters the muffler. If it's 1 7/8" a 2" muffler will fit... if the pipe is 2", then you'll need a 2.25" muffler. The muffler will need to be offset inlet, offset outlet and be oriented on it's thin edge (standing on it's side).
