k9t8m
Rollin' Twankies
5speed mark viii for sale
$6500
1997 Mark VIII Base
TR3650 swapped (05+ Mustang with remote mount shifter)
373s with Trac Lock
13" cobra front brakes
cobra rear brakes
Mustang hub swapped
high miles on chassis
4k mi on trans swap
67k on engine
Addco front and rear sway bars and rear end links
delron rear subframe bushings
cobra rear bilstien shocks
cobra exhaust manifolds with custom full exhaust
custom tune to support 5sp swap
optima yellow top battery
original HIDs work
original rear neon works (emblems shaved)
aftermarket head unit with aux input for ipod
tinted windows
LSC grille, LSC headlight trim, LSC side moldings
custom grill emblem
ray's switch (to dump air ride)
Wrinkle black powdercoated valve covers
I am currently using it as my daily driver. Its got a set of winter wheels and tires on it. The saleens have maybe 200 miles and are waxed and in storage for the winter. If you don't want the saleens, I also have a set of mustang fanblades with bfg's on them with about 50% tread left.
Here is the build thread from LvC. I bought the car from Mike (94m5) who is a very good friend of mine, he owned the car for a couple years. We both are also good friends with the previous owner before that, he owned the car for close to 10 years, and it spent most of its life in NJ. It has not been used as a winter car until I got it this year.
http://www.lincolnvscadillac.com/for...Ivory-Progress
I did want to let you know that the coil covers in the pictures will not be included.
It does also have a check engine light on having to do with the trans swap.
The only other things that need addressed is the traction control\abs only works intermittently. Both rear abs\speed sensors need replaced and that problem will be fixed.
It also needs an upper shock mount on the lt rear, and one, if not both of the rear wheel bearings replaced.
I think I have covered just about everything, but if you have any questions just let me know. Thanks
$6500
1997 Mark VIII Base
373s with Trac Lock
cobra rear brakes
Mustang hub swapped
4k mi on trans swap
67k on engine
original HIDs work
tinted windows
custom grill emblem
