Madd4mercs
Greetings to all at LVC,
Sadly, my 97 MK VIII needs transmission work as it has begun to slip between gears. At 244,000 miles, I am not complaining. Since the tranny in my VIII needs work anyway, now would be a good time to upgrade to a newer transmission if the swap is fairly straight forward. I am thinking that a 2009 ford f150 4x2 with the 4.6 3v should be a direct fit between engine and transmission (same flywheel teeth number?) with a drive-shaft length issue and computer control issue being the biggest challenges. Has anyone successfully swapped in a newer Ford automatic 6 speed 6R80 transmission into their MK VIII? If yes, could you please provide some information. Thanks
