well well well hello.. finding this place is like getting a belated Christmas present .. I guess I'll put off taking this car to the repair shop for a few days.
I have a '88 MK 7 LSC, 5 Liter EFI, HO engine. 200K miles on the car, only about 30 k on the new engine.
One day hard to start, the next it wouldn't start.
Cranks normally but no fuel? It will start by priming the intake maniifold with gasoline or starter fluid. As is normal for this car, it's a rocket ship thereafter.
Turn the key a couple times and fuel pressure at the schrader valve is strong so fuel pump at start is OK, pump relay is OK.. Since priming the engine works, spark during cranking is OK too? There are no running problems at all and no restarting troubles if the engine stays warm.
One other clue is the idle is low when cold started .. near 800 instead of 1200 RPM. The computer seems to think the engine is warm?
I bought a $34 code reader. Key On Not Running code is 34. This code is also in the EEC memory.
(I have all service manuals except the one i need.. "Engine/Emmissions diagnosis Vol H " but i'm gonna order that immediately.)
So, code book says stuff about code 34, like :
Insufficiient EGR flow (or not opening properly)
EVR - EVP sensor is/was high - EVR
PFE - PFE sensor is/was out of range - PFE
Defective EGR pressure transducer sensor
At this point i'm sorta lost. I thought i'd ask you people before buying new EVP or PFE or EVR sensors, assuming i manage to discover what and where they are. Hopefully i've provided enough info to diagnose this no-start problem or at least narrow it down to replacing a couple sensors. Any advice is most appreciated and i'll do my best to answer any questions.
btw.. i'm not bragging but i got lucky.. and got this car for free about 2 years ago. Lincoln searched but could not find an ABS (yellow dummy light) problem and wanted $3500 for an entire new brake system. Headed for the junkyard?
I (somewhat unwillingly) took the car and after a few days pulled the rubber brake hose off the resevoir.. I had a tin can ready but nothing came out (??) The built-in filter at the bottom of the brake fluid reservoir was clogged up.. The pump was overheating/shutting down intermittantly. Brake-fix cost me $6 for a salvage yard reservoir. I guess Lincoln limited it's $100 diagnosis to a code reader or something..
