Im working on an 89 Town Car and replacing all of the brake lines. In the front of the car , I imagine thet they go into the prop valve, but I can't see how they are routed in there. Any suggestions?? Thanx.
If I rember correctly on my 87, it should be on the bottom driver side - right behind the fender towards the bottom. If you look in the front driver's side wheel housing well there will be a cover about the size of a potato that you can pop off - towards the rear of the wheel housing - behind that cover will be the prop. valve.
