crosscomp
My trouble started when the throttle position sensor went bad(replaced that)
then the tranny wouldn't shift into 4th and it felt as if it was stuck in 2nd or third( sluggish on takeoffs ), changed filter and fluid (thinking maybe filter plugged) no change. then I changed the vacume modulator(still no change),
Could the valve behind the modulator be stuck or clogged. Is the shift points controlled by the computer and if so how do I tell if the ECM has gone south?
If the tranny has died how hard is it to change?
Sean
Sean
