93 transmission special?????
nocalking
chico
I have been reading about the j-mod, and I saw once (can’t find again) that the 93 transmission was special and you had to do different things to it; different drill bits if I’m right. When I was on TCCoA everything that I had read had said 94 and newer.
should I just do it like all the other transmissions or am I missing something?
Maybe you're thinking about your one piece drive shaft. Yes, more bits required for the 93 trans and only two for the 98.
