we have recently replaced all four struts,solenoids, compressor and dryer.
our problem is that the compressor does not want to air up the bags. we can hear the compressor running for approx 2-3 minutes and then shut itself off. what little air does go into the bags if any seems to leak out. we have tried disconnecting the battery and reconnecting and this does not help. all this has been tried while on the ground or with the frame raised and neither seems to be effective. the vehicle is currently stuck on the ground with the lift underneath and cannot be moved. any suggestions you can give would be appreciated.
