94 conti air ride
ozy3330
WBL
Just replaced rear air ride and now back end is lower than I would like how do I raise it up manually. Thanks for your help
There should be a air fiitting on the air ride compressor looks like a valve stem, you can add air that way. :W to :V
Welcome to the site!! The bags are new, so If there is a component at fault for it riding to low, I twould be a weak compressor, or bad height sensors. Need a better description of what is exactly going on to tell you more. Please describe in more detail.
Anyways again welcome to the site, were glad to have ya here.:Beer
Well the compressor is new , I had to change the rears because one decided to pop on me when I was replacing them I accidently took the rear height sensor off and not sure where it was set at but it isnt "on the ground low" just lower than I like. thanks again for the help
I would just try adjusting the rear height sensor. I had the same problem on mine when I installed a new height sensor.
:I Try and adjust the height sensor. If you have a ford manual, Chilton/haynes etc. It should tell you what it should be at. 9 times out of 10 with new bags a height problem is the sensor.
