94 Mark
Cheez_94
Conservative hell
Great shape, just turned 100k. Portofino/portofino. front 1-1/2 lower springs rear manual bags (but have springs for rear). Drilled, slotted front rotors and carbon ceramic pads. Needs highside ac line (still presure on system), rear sway bar and drivers door panel (cracked) Struts, springs and brakes w/i the last 6 months. $2,000 firm located in central IL
Thanks for the heads up, that ad was long ago so I thought it had died. I didn't get even one PM off that one (contrary to what lincoln lerker had to say)
Did you pick up that Green Mark for sale in Carlock?
no, that car is a freakin turd. not worth $200.
LOL sounds like that black one thats still for sale in Champaign for 350, what a POS the only good part on that car is probably the engine block
This one in Sullivan is no jewel either, http://chambana.craigslist.org/cto/1619916507.html I suspect there might be a problem with the air ride it looks like the rear is higher in one pic than the other. It's low miles but sometimes that can be a bad thing depending on the maintenance.
Mine was a one owner when I got it and I have had it for 30K. Not being driven can actually be a bad thing especially for bushings. The old guy I got mine from started and ran it religiously even if he wasn't going to drive anywhere but all that cars sitting had me replacing just about every bushing in the car shortly after I bought it
