94 SLS Cold Start problem
dan tharp
columbus
Have a '94 SLS that recently has taken 2-3 cranks before it starts in cold weather, and then it gurgles and stammers for a little before it runs smoothly. Car will start fine if it is warmed up. Had the fuel filter replaced about 30,000 miles ago, but the line they put on is a little long, and the filter hangs kind of low and at a slight angle. Fuel pump is not making any noises, but I can (faintly) hear it kick on when I turn the ignition switch to the "on" position (as I believe it is supposed to do.) I ran fuel system cleaner to clean injectors and additive to remove water from the fuel line. Doesn't seem to be a serious problem, but would like to get it fixed. Any ideas?
