94 SLS, starting problems
SensesFail32
Columbus
i have a 94 seville sls that i bought 2 weeks ago, needs a little maintenance and now some work. i got it 2 tuesdays ago it drove fine till this past sunday, then i parked it at my house, went inside came back out and it wouldnt start, first i tried turning it over and it would start but bogg down and eventually die, it did that for a while and i let it sit for a day or so and now it wont even start up. i went and got a diagnosis when i went and got an oil change and they said i need a radiator and tranny flush, also i have an a slow oil leak and i need to change my fuel filter. the guy i bought it off of said he needed to change the fuel filter before so im thinkin that might be it, if anybody can help please let me know, thanks
sounds like a fuel filter...but it should still run. could be a clogged injector(s), what type of fuel grade u run? Any smoke? You need to give more details than bogged down wont run, etc.
be thorough since we are not there, noises, starting, checks, a tranny flush isnt why the engine isnt running, and a radiator isnt the problem either, (an engine will run hot)
more info bro
the mofo
fuel pump relay
Also check the fuel pump relay. Its located under the hood in the drivers side wheel well. If this is bad it will cut off your fuel pump and starve your engine of gas!! Easy fix if its it.. :C
my fault i tried to remember everything that was happenin, but i use premium, 92 or high, nah there wasnt any smoke, but the only noises it was makin what when i tried turnin it over, just the normal clicking noise, just not normal, more slow or i dunno how exactly to explain it, buddy of mine said it could be the fuel pump
